Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove your SD card, battery, SIM(s) and cover. To remove the cover, you grab the top of it and put your thumb on the middle of the case and pull towards yourself.
Hmmm... I wonder what that part (marked in green) does....
Unfortunately, because I don't have the necessary tools to continue this teardown, I will let anyone with a Lumia 532 (Dual SIM or not) continue this guide and improve it.
Tip: If you don't have a Torx Screw Driver or bit, use a small flat screw driver. Align it in a position where you can spin the Torx screws safely. This chips the paint off the screws, though.
2 участников успешно повторили данное руководство.
