Microsoft Lumia 535 - Factory Reset, Screen Lock Removal
Видео обзор
  1. Microsoft Lumia 535 - Factory Reset, Screen Lock Removal, Microsoft Lumia 535 - Factory Reset, Screen Lock Removal: шаг 1, изображение 1 из 3 Microsoft Lumia 535 - Factory Reset, Screen Lock Removal, Microsoft Lumia 535 - Factory Reset, Screen Lock Removal: шаг 1, изображение 2 из 3 Microsoft Lumia 535 - Factory Reset, Screen Lock Removal, Microsoft Lumia 535 - Factory Reset, Screen Lock Removal: шаг 1, изображение 3 из 3
    • Switch off the phone.
    • Press and hold the Volume Down button and connect your charger. When you see an exclamation mark release the button.
    • Now press the keys in this sequence:
    • Volume Up
    • Volume Down
    • Power
    • Volume Down
    • The phone will reset and reboots.
    Please help me i have problem resrting my phone..
    kier jumento - Ответить
    what a great Method .it work ........... thankx for genius method
    usmanmanga85 - Ответить
    please help, I just did the hard reset but now it's denying my microsoft account login...
    i did the reset but failing to login my account and now I cant do anything. Im stuck on the sign in page...
    Chido Marufu -
    i did reset but now cant login and cant access anything...
    Chido Marufu -
    Chido Marufu -
    my phone cant touch anymore i hve microsoft mobile rm-1089.after hard reset the phone reboot and stuck at language selection no touch at all been hard resetting over and over. .any help?
    bedelfever - Ответить
    bhai mayra nhi ho rha
    ns890157 - Ответить
    it worked thnks ilove the tips
    dex vin - Ответить
    Approximately how much time is it supposed to take?
    Aashka Vora - Ответить
    This not working what else can I do?
    Oluwakemi - Ответить
    Thank you so much you r great. I have done.....thanks
    Rakshit - Ответить
    fantastic.Thank you so much
    Kirti Sethia - Ответить
    Awesome…Thank You so much…
    Bipin Bihari Sethi - Ответить
    After I press the volume down key and insert my charger no exclamation mark appears so what do I do??
    Richard Donkor - Ответить
    I am re start the phone as per instructions but the phone will not be open.
    Still the exclamation mark appears
    What I do?
    Siva ganesh - Ответить
    I followed the hard reset procedure, but when I press the volume up button, the phone goes off. I have not had the chance of pressing the other buttons. Please help me if there's any other method. Thanks
    Lawrence Kumah - Ответить
    Very well... Thank you...
    Ankita Kar - Ответить
    How do i cancel the hard reset?
    Yadira Ruiz - Ответить
    Smash it! Hard on the ground. Quick.
    Edgar Cintron -
    resetting in progress. Thanks
    Benjamin Bara - Ответить
    wa za mara da kho mata yada wa
    niamatullah123 - Ответить
    good and easy mode.
    thanks a lot
    MAHAM NAZIR - Ответить
    I did reset but my restoration code isn't received. Same phone number and email address but still have not been able to receive code. Please help. How will I receive code. I'm checking my email for code. No text message received yet.
    Arabi - Ответить
    It really worked. Thanks for the post
    braphord saunders oliver - Ответить
    Thanks it works and make sense
    HAMMED ALAGBE - Ответить
    Thank a lot, its working.
    P Gana - Ответить
    Volume up button is not working…. Any other way of reset my phone??
    Raja 12345 - Ответить
    I can’t install any app on my windows phone
    Chaudary Ibrar - Ответить
    I did get the exclamation point symbol but now it has more of a lighting bolt w the settings symbol. Can't do anything to it now? Please reply. I appreciate the help so far.
    miranda hackford - Ответить
    Has anyone recieved any reply back?
    You sir are a beast.. Beautiful.. It work for me.. Thanks! Edgar lynn ma..✌
    Edgar Cintron - Ответить
Заключение
Your device is now reset!
193 участников успешно повторили данное руководство.
ZFix
Участник с: 12/09/13
191 308 Репутация
Автор 330 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 535 руководств
112 Комментариев
thanks a lot!!
very useful!
suchitra kumar - Ответить
THankx for your help..
Pinak - Ответить
but my mobile timeing was 107 and this step are not work that
shahaji jadhav - Ответить
same with me.
can you help me? I try the step but is not work in my mobile timing is 790880. how to remove those screen password?
Alden Hammisain -
worked for me...thanks
erick - Ответить
It really worked for my Microsoft Lumia 535. Thanks
Tiamiyu Babatunde - Ответить
how did you do it because mine turning on as soon as l press the volume up button
alfredjunior -
Thanks A lot. Saved my day
Shivam Jain - Ответить
When i press that button nothing happen to the phone it only starts..
When i press that button the phone starts and nothing happen
did your work out
alfredjunior -
when I followed what you have stated, my phone could not load up the exclamation mark but shows battery charging sign
jobstevegimisimo - Ответить
Answer to skipping ! Symbol and going straight to battery charging symbol?
Albert einstine -
It worked greatly thank you very much it is greatly greatly appreciated it was just as simple as it is explained!!!
Tifani Hill - Ответить
worked for me thanks man.
Will Hanson - Ответить
thank you very much for a wonderful solution.
satya033 - Ответить
i followed the same instructions, but when I press the start button my phone switches on and goes back to the password locked screen.
Jyoti Raj - Ответить
Thats what mine is doing did u find a solution
Shamekia Mitchell -
Não resultou... Fica em loop mostrando as engrenagens e depois uma carinha triste
Que posso fazer para voltar a ligar o telemóvel??
andreiapanatal83 - Ответить
You knw Actually the lock has been broken but i duano what is next step mean while it's asking to fix some point for which look forward to get this done.
Akash Kumar - Ответить
%#*@ it actually worked
Alex Teano - Ответить
it is not working on my phone pls tell me another solution
AJITH TV - Ответить
Thanks for your very good information
b17karthik - Ответить
did we lost win 10 switch back to win 8.1 from win10 after factory reset?
my lumia 535 face screen freeze and some time auto power off and power button not working problem
when I press power button it show dim light and black screen again and also got heat up from upper front back side
the only thing work in these issue is remove back cover put off battery put in again
hasan_rameez - Ответить
The author did an excellent job that deserves commendation.The steps were so easy and straight forward
Alabi Tajudeen - Ответить
good on ya mate thanks for trick
emreozcicekci - Ответить
Wow thank u my IT It's work for me from Ernest tnx an tnx again my god bleessd u
bongs_72 - Ответить
Tnx my IT its worked for me
bongs_72 - Ответить
lumia 535 copied recovering mode
ashleys69 - Ответить
thanks to ya, it really worked............. thanks to the crew
bi jay - Ответить
Chido Marufu - Ответить
It works for me lumia 540 thanks a lot....for your valuable suggestion..
Raghu Raghu - Ответить
Thanks a lot it really work for me......kudos
philipbrown6743 - Ответить
I try it but it really really and extremely work for me thanks a lot
awesome it really works. thanks alot
henry fundi - Ответить
My phone appears (try again in 1034387 minutes) and could not open. Please help me. URGENT
chenthin707 - Ответить
Thaaaaaank Youuuuuu soooo mucccchhh
Alber Einstein - Ответить
This process is fully working if Your touch is Not working
It's like a GTA cheat code from the ps2 days, btw it worked for me :<}
Shaquille Richards - Ответить
My friend asked me to unlock it, I just tried in search engine. It helped me at right..
Haridass - Ответить
It worked thank ya vry much amigo
Abdullah Twait - Ответить
did that, saw the gears then went to a sad smiley, please help.
Mharc - Ответить
thank you sooooooooooooooooooooooooooooooooo much
IHSAN ULLAH - Ответить
can I do that on my phone but it has no power
Nash Rutsate - Ответить
please help, can I do that on a powerless phone
It is working but after reset edge browser is missing old help me
Prashanth D - Ответить
Cool! Other remember to remove you sceenlock first before trying this, then it will work/
Liam Decker - Ответить
My phone is reset but its asking reset protection key. What can i do
Uday Urs - Ответить
how much time it should take to reboot and start
VANDAN NAGAR - Ответить
Whats the answer to the timeframe regaurding how long does it take fof the reset to take?
Albert einstine -
Whats the eta for reset
Albert einstine -
Thanks to the author, for his excellent work.
aparesh datta - Ответить
Thanks to the author for his excellent work.
Not working for me. Pls help to reset password.
Bhuvana Vaithilingam - Ответить
This method Not working for me. Phone only starts. Pls help me.
My mircosoft windows phone will not factory reset
Louise Hopson - Ответить
You are really genious bro… Awesome…
Thanks and it works for me very nicely…
Md. Mehedi Hassan Shawon - Ответить
You are a guru, genius, in fact Einstein….. thanks a lot
Dhermy Machessy - Ответить
You,re great !!!!!!!!!!!
keep it going. Love you, May God bless you Sir
Raj Kamal - Ответить
Cheers man…it worked. God bless
samuel kalel - Ответить
Good work! works like a charm!
qash miik - Ответить
Awesome! I'm overjoyed, the steps were
Kameswari - Ответить
If it failed for you try it this way without the charger: Press the power button to start and when it vibrates hold the volume down button until it shows you the exclamation mark. the do the volume up down power down sequence mentioned above here and leave it aside to show the logo then spinning cog wheels. The charge route failed for me too till i found the route where you dont include the charger.
romeohammer3 - Ответить
The reset worked but it is asking for a reset protection recovery key that I am not able to get
Debbie Reid-Jones - Ответить
Thank you vry vry much…
vinod Tolani - Ответить
thank’s dude worked bang on……
mizer006 - Ответить
it’s working.. although we have it trial and error, and thank to you…
rotsennoziuk - Ответить
Thank so much it really work perfectly for me
aisivbiekpen - Ответить
thanks you so much.. you are awesome …..
tejipta - Ответить
phone restarts when i hold volume down
can’t reset
Shubham Sharma - Ответить
you are good lumia, great job done
ANANIVI EMMANUEL 18-10-2014 - Ответить
thank you. my friend lost her phone so she’s going to use her previous phone and ask me to do a hard reset. great help dude!
milenyume_gyrl_23 - Ответить
Omg….Your my HERO! :-)
Shelby Jean - Ответить
HI Team,
My phones touch is not working since last night…please help
Shyam Sunder - Ответить
mine is refusing to go to the main menu
lucienne.lune - Ответить
you can also reset your lumia by going into settings, scroll down and chose about phone in there it gives you the option to reset phone click on and you will be prompted are you sure press OK and it will shut down and when it restarts it will show 2 cogs turning this take about 2/3 minutes, you now have your phone back to factory set. hope this helps those who could not do it the other way?
Klite - Ответить
It’s been 1 hour and the wheels are still rotating. What should i do? :( :( :( :(
Alim Al Razi - Ответить
great help. now i can use my phone again . i love the feathers but soon it will be dead as microsoft unable to tap the market potential of windows phones any more
khaniftikhar761 - Ответить
super reset method of mobile .
Dattaraj Naik- 10-09-2019
Dattaraj Naik - Ответить
Wow!! It really worked like a charm.. thanks for sharing this
Ricky Ross - Ответить
Volume up button not working…. Any other way of reset my phone???
Done this but the former owner had the reset protection on and now it wants the recovery key
Stanford Adams - Ответить
While the update is underway, the outbreak has come to an end. Then a mark comes up on a display
Sasikaran Sakilan - Ответить
Thank you this was extremely easy . I have this as a back up phone . I dropped my Galaxy S10e and destroyed the screen I had forgotten the pin lock on this one and needed a fully operable phone for the next few days while I wait on my replacement from the insurance.
Sanity is restored
Kelli Martin - Ответить
When exclamation mark appears and i press Volume Up button. exclamation mark disappears before even I press volume down button
Syed Azaz Ul Hassan - Ответить
मेरे फोन में इस गतिविधि से चरखा सा चलने लगा
Vikas Sheoran - Ответить
grazie infinite, ho resettato il Lumia 535 con molta facilità di nuovo grazie!!!!
drapar - Ответить
Badass that work as explained
juggalojerm19 - Ответить
Thanks for help but it takes so much time
Prajwal Mahadik - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 35
За последние 30 дней: 170
За всё время: 388,380
