Введение
Microsoft Lumia 535
RM-1090 / RM-1091/ RM-1089 / RM-1092
How to disassemble the phone and replace broken, smashed Display or Touch Screen Glass Digitizer.
!!!There are different versions touch screens:
• CT2S1973FPC-A1-E
• CT2C1607FPC-A1-E
The version is printed on the flex cable.
Выберете то, что вам нужно
Видео обзор
Turn off the phone.
Remove the battery and any SIM and memory cards.
Disconnect:
Touch screen flex cable
LCD Display flex cable
Charging Dock board flex cable - remove the foam and tape, then flip up the black lock before easing out the flex.
Coaxial antena cable - take your time here, be sure to pull the metal connector and not the cable or you risk pulling the cable from the connector.
Remove the 2x Torx T4 screws.
Remove the display flex cable rubber.
Put scotch tape on glass to prevent it from shattering.
Use a hair dryer or heat gun and warm the glass to make adhesive soft.
Use a cutter or other tool with a sharp edge and start the separating from the bottom side. When you make enough room, continue the operation with a plastic tool.
Using a plastic tool, carefully remove the display.
Clean the frame from the remainders of the old adhesive.
Install the touch screen and start with the reassembling.
That's all.
Did you do it successfully?
50 участников успешно повторили данное руководство.
19 Комментариев
hi
cane you tell me price of out glass of lumia 535 duol sim please ?!
I want to join in your team
Hi,How to know which the versions touch screens my phone is Lumia 535 RM-1089 , please?
