Введение
This guide will show you how to remove and replace the battery in the Microsoft Lumia 640 XL.
Выберете то, что вам нужно
Place left palm on screen and right palm on the back.
Press down with fingertips and pull to separate the back from the screen.
Remove all ten T3, 4.09 mm screws.
Lift mid-frame assembly from phone with flat side of a spudger.
Lift off connector with tweezers.
Lift motherboard off with tweezers and pull away with fingers.
Disconnect the rear facing camera from the motherboard with tweezers.
