Введение
A guide showing how to disassemble and clean a Microsoft Natural Multimedia Keyboard.
Выберете то, что вам нужно
You will need a spudger to remove the keys. An IC mounting tool can be helpful in replacing them.
Wider keys will have a retaining bar, take note of how they come off to make reassembly easier.
Continue removing keys.
Remove the 10 screws from the bottom of the keyboard.
Remove the upper button assembly.
Use the tip of a spudger to push the upper button assembly buttons out from the back.
Remove the flexible keypad from the key caddy assembly.
The key caddies can be washed in the sink.
9 участников успешно повторили данное руководство.
3 Комментариев
Thank you so much! I had never done this before and was very confused by the retaining bar.
I’ve had this keyboard since it was released and it just recently started having key sticking issues, so I opted to follow this guide and was pleasantly surprised at how well it worked. Thank you for this and I hope to get another 15 years out of it.
Suggestions:
1) Instead of manually cleaning, put the keys into a clear mesh bag and into the dish washer or washing machine.
2) Spray metal retainer bars with WD-40 and wipe off to help further prevent rust.
3) Let the keys and caddies sun dry for the day to ensure they do not retain any water after cleaning.
great guide.
