Microsoft Surface 2 Speaker Replacement
Выберете то, что вам нужно
  1. Microsoft Surface 2 Speaker Replacement, Screen: шаг 1, изображение 1 из 3 Microsoft Surface 2 Speaker Replacement, Screen: шаг 1, изображение 2 из 3 Microsoft Surface 2 Speaker Replacement, Screen: шаг 1, изображение 3 из 3
    • Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
    • Avoid holding the heat gun too close to the Microsoft Surface 2 so as to not cause any unwanted warping.
    • Avoid touching the metal end of the gun. It will be very hot and can burn you.
    • Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
    • Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
  2. Microsoft Surface 2 Speaker Replacement: шаг 2, изображение 1 из 3 Microsoft Surface 2 Speaker Replacement: шаг 2, изображение 2 из 3 Microsoft Surface 2 Speaker Replacement: шаг 2, изображение 3 из 3
    • Once the screen is free from the body, there will be a single ribbon cable connecting the screen to the motherboard.
    • Use a plastic spudger to pry the retaining clip away from the display cable.
    • The ribbon cable may be glued to the motherboard.
    • Carefully pull the ribbon cable from its socket on the motherboard.
  3. Microsoft Surface 2 Speaker Replacement, Speaker: шаг 3, изображение 1 из 2 Microsoft Surface 2 Speaker Replacement, Speaker: шаг 3, изображение 2 из 2
    • Work close to Magnetic Project Map to avoid losing screws.
    • Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
    • Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
    • Once all screws have been removed, lift and remove the bezel from the rest of the device.
  4. Microsoft Surface 2 Speaker Replacement: шаг 4, изображение 1 из 1
    • Using a T3 screwdriver, unscrew and remove the 3.5mm screws holding down the silver plates located at the corners of the device.
  5. Microsoft Surface 2 Speaker Replacement: шаг 5, изображение 1 из 2 Microsoft Surface 2 Speaker Replacement: шаг 5, изображение 2 из 2
    • Using tweezers, remove the cable connecting the speaker to the motherboard.
    • Peel up the tiny strip of yellow tape securing the cable to the motherboard.
  6. Microsoft Surface 2 Speaker Replacement: шаг 6, изображение 1 из 2 Microsoft Surface 2 Speaker Replacement: шаг 6, изображение 2 из 2
    • Lifting from the inmost end of the speaker, use a spudger to carefully pry the speaker from the motherboard.
Заключение
Еще один человек закончил это руководство.
EG1
Участник с: 02/04/16
597 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 3-1, Wollert Spring 2016 Участник USF Tampa, Team 3-1, Wollert Spring 2016
USFT-WOLLERT-S16S3G1
4 членов
Автор 5 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 14
За всё время: 1,204
