Введение
Over time, the rubber feet on the bottom of your laptop can get worn out or fall off. Follow this guide to replace the feet on your Microsoft Surface Laptop 4 (13.5-inch).
Выберете то, что вам нужно
Close the screen and lay your laptop down with the rear case facing up to access the four rubber feet.
The back feet recesses are closest to the back edge of the laptop.
The front feet recesses are closest to the front edge of the laptop.
Инструмент, используемый на этом этапе:Tesa 61395 Tape$5.99
The rear feet have a single center clip.
The front feet have three clips and can only be reinserted one way.
If the existing feet no longer adhere to the frame, remove the old adhesive and apply a small amount of Tesa Tape where the old adhesive was.
Peel a pad away from its backing.
Align the pad over a foot cavity and press down to secure it.
