Microsoft Surface Pro 2 Audio Ports Replacement
Выберете то, что вам нужно
  1. Microsoft Surface Pro 2 Audio Ports Replacement, LCD Display: шаг 1, изображение 1 из 2 Microsoft Surface Pro 2 Audio Ports Replacement, LCD Display: шаг 1, изображение 2 из 2
    • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
  2. Microsoft Surface Pro 2 Audio Ports Replacement: шаг 2, изображение 1 из 1
    • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
    • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
    • The glue is under the darker border of the device display.
  3. Microsoft Surface Pro 2 Audio Ports Replacement: шаг 3, изображение 1 из 1
    • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
    • If the tool does not easily slide under the screen, return to heating before proceeding.
    • Slowly work the tool around the entire edge of the screen.
  4. Microsoft Surface Pro 2 Audio Ports Replacement: шаг 4, изображение 1 из 3 Microsoft Surface Pro 2 Audio Ports Replacement: шаг 4, изображение 2 из 3 Microsoft Surface Pro 2 Audio Ports Replacement: шаг 4, изображение 3 из 3
    • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
    • Please note the third small connector in red.
    • Allow the glue to cool before letting it come into contact with any other surface.
  5. Microsoft Surface Pro 2 Audio Ports Replacement, Motherboard: шаг 5, изображение 1 из 3 Microsoft Surface Pro 2 Audio Ports Replacement, Motherboard: шаг 5, изображение 2 из 3 Microsoft Surface Pro 2 Audio Ports Replacement, Motherboard: шаг 5, изображение 3 из 3
    • Make sure that the front-facing camera is completely disconnected, and then remove the plastic bracket.
    • Remove the 22 screws on the bezel.
    • Remove the left and right brackets; the left has 16 screws and the right has 15 screws.
    • The three different torx screws used are T3, T4, and T5.
  6. Microsoft Surface Pro 2 Audio Ports Replacement: шаг 6, изображение 1 из 3 Microsoft Surface Pro 2 Audio Ports Replacement: шаг 6, изображение 2 из 3 Microsoft Surface Pro 2 Audio Ports Replacement: шаг 6, изображение 3 из 3
    • Once the brackets are removed, set them aside.
    • The motherboard itself also has screws.
    • Remove the 25 screws of varying sizes that attach the motherboard to the back plate.
    • View the attached photo of a screw diagram to help keep track of your screws.
  7. Microsoft Surface Pro 2 Audio Ports Replacement: шаг 7, изображение 1 из 3 Microsoft Surface Pro 2 Audio Ports Replacement: шаг 7, изображение 2 из 3 Microsoft Surface Pro 2 Audio Ports Replacement: шаг 7, изображение 3 из 3
    • You have now completely removed the motherboard, and it should look like the pictures shown.
    • Be sure to be cautious with all the connections with the cables on the motherboard.
  8. Microsoft Surface Pro 2 Audio Ports Replacement, Audio Ports: шаг 8, изображение 1 из 2 Microsoft Surface Pro 2 Audio Ports Replacement, Audio Ports: шаг 8, изображение 2 из 2
    • The entire assembly can be removed by taking out one final screw.
    • These screws as well as the ribbon were removed during the perquisite guide for removing the motherboard.
Заключение
Mathew B
Участник с: 09/19/16
323 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 6-2, Remmell Fall 2016 Участник USF Tampa, Team 6-2, Remmell Fall 2016
USFT-REMMELL-F16S6G2
4 членов
Автор 9 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 1,146
