Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
Use tweezers to slide the display cables straight out of their sockets on the display board.
Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
Инструмент, используемый на этом этапе:Tesa 61395 Tape$5.99-
Remove the display board.
To ensure correct positioning, plug in both display connectors before adhering the board to the display.
Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
Repeat the last step for each corner of the EMI shield covering the heat sink.
Remove the ten Torx screws securing the heat sink:
Five 2.6 mm-long T3 screws
Four 3.3 mm-long T5 screws
Screw 1
Screw 2
Screw 3
Screw 4
Use the flat end of a spudger to gently pry the heat sink straight up and off of the CPU.
Remove the Torx T5 x 6mm screw connecting the black tie bar to the power button/volume control/speaker assembly.
Remove the remaining three Torx T5 x 4.5mm screws holding down the camera tie bar.
Disconnect the small ribbon cable connecting the camera tie bar to the motherboard by pulling up with tweezers.
Еще один человек закончил это руководство.
2 Комментариев
Do you really need to remove the heat sink shield and the heat sink to disconnect the tie bar small ribbon cable ?
