Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The kickstand of your Microsoft Surface Pro 5 is a convenient feature of the device, but if it breaks off or stops holding your tablet upright, you may want to replace it. Follow this guide to replace the kickstand of your Microsoft Surface Pro 5. This is a quick and easy repair that will greatly improve the usability of the Surface Pro 5.
  1. Lift the kickstand about 90º to reveal the hinges. Lift the kickstand about 90º to reveal the hinges. Lift the kickstand about 90º to reveal the hinges.
    • Lift the kickstand about 90º to reveal the hinges.
  2. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    Shop Kits
    Enough RAM
    For All The Tabs
    Shop Kits
  3. Remove the four 2.7 mm T3 Torx screws, two from each hinge. Remove the four 2.7 mm T3 Torx screws, two from each hinge.
    • Remove the four 2.7 mm T3 Torx screws, two from each hinge.
  4. Lower the kickstand to about a 15-30º angle from the device. Gently pull the kickstand away from the device, rocking left to right to disengage the adhesive tabs connecting the kickstand to the device.
    • Lower the kickstand to about a 15-30º angle from the device.
    • Gently pull the kickstand away from the device, rocking left to right to disengage the adhesive tabs connecting the kickstand to the device.
    • During reassembly, be sure to reinsert the two adhesive tabs into the slots on the back of the device before installing the screws in the hinges.
Заключение
Еще один человек закончил это руководство.
Sarah Westberg
Участник с: 11.03.2019
3 939 Репутация
Автор 22 руководств
Команда
iFixit Участник iFixit
Community
129 членов
Автор 12 470 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 30
За последние 30 дней: 135
За всё время: 1,007
