Microsoft Surface Pro 5 Right Speaker Replacement
Выберете то, что вам нужно
  1. Careful: steps 1-22 are sourced from a guide that's marked as in-progress.
    Microsoft Surface Pro 5 Right Speaker Replacement, Heat the screen: шаг 1, изображение 1 из 1
    • Completely power off the Surface before you begin disassembly.
    • If the screen's glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass. Lay overlapping strips of clear packing tape over the display until all the glass is covered. Wear safety glasses to protect your eyes.
    • Heat an iOpener and apply it to the right edge of the Surface's screen for two minutes.
    • You may need to reheat and reapply the iOpener several times to get the Surface warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used for more heat, but be careful not to overheat the Surface—the screen and internal battery are susceptible to heat damage.
  2. Microsoft Surface Pro 5 Right Speaker Replacement, Take note of the adhesive layout: шаг 2, изображение 1 из 2 Microsoft Surface Pro 5 Right Speaker Replacement, Take note of the adhesive layout: шаг 2, изображение 2 из 2
    • Take note of the screen adhesive layout before continuing:
    • These areas only contain adhesive and are safe to cut.
    • The display board and flex cables sit here close to the edge. Cut very carefully and do not insert the pick as deep under the display.
    • Fragile antenna cables lie under this part of the screen. Carefully follow the procedure to avoid damaging them. The adhesive is also the thickest here.
  3. Microsoft Surface Pro 5 Right Speaker Replacement, Insert an opening pick into the speaker opening: шаг 3, изображение 1 из 2 Microsoft Surface Pro 5 Right Speaker Replacement, Insert an opening pick into the speaker opening: шаг 3, изображение 2 из 2
    • Insert an opening pick into the speaker opening on the screen and slide the pick under the glass. Do not press the pick into the speaker grille, as the grille is easily torn.
    • Don't insert the opening pick any deeper than the black bezel on the side of the screen. Inserting the pick too far may damage the LCD.
  4. Microsoft Surface Pro 5 Right Speaker Replacement, Slide an opening pick under the screen: шаг 4, изображение 1 из 2 Microsoft Surface Pro 5 Right Speaker Replacement, Slide an opening pick under the screen: шаг 4, изображение 2 из 2
    • Rotate the pick toward the bottom of the Surface to slide it underneath the lower edge of the speaker cutout.
  5. Microsoft Surface Pro 5 Right Speaker Replacement, Cut through the screen adhesive: шаг 5, изображение 1 из 2 Microsoft Surface Pro 5 Right Speaker Replacement, Cut through the screen adhesive: шаг 5, изображение 2 из 2
    • Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
    • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
    • Leave this opening pick in the right edge to prevent the adhesive from resealing.
  6. Microsoft Surface Pro 5 Right Speaker Replacement: шаг 6, изображение 1 из 1
    • Reheat the iOpener and apply it to the bottom edge of the Surface's screen for two minutes.
  7. Microsoft Surface Pro 5 Right Speaker Replacement: шаг 7, изображение 1 из 3 Microsoft Surface Pro 5 Right Speaker Replacement: шаг 7, изображение 2 из 3 Microsoft Surface Pro 5 Right Speaker Replacement: шаг 7, изображение 3 из 3
    • Insert a new opening pick into the bottom right corner and slide it around the corner toward the bottom edge.
    • Slide the pick along the bottom edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the bottom edge to prevent the adhesive from resealing.
  8. Microsoft Surface Pro 5 Right Speaker Replacement: шаг 8, изображение 1 из 1
    • Reheat the iOpener and apply it to the left edge of the Surface's screen for two minutes.
  9. Microsoft Surface Pro 5 Right Speaker Replacement: шаг 9, изображение 1 из 3 Microsoft Surface Pro 5 Right Speaker Replacement: шаг 9, изображение 2 из 3 Microsoft Surface Pro 5 Right Speaker Replacement: шаг 9, изображение 3 из 3
    • Insert a new opening pick into the bottom left corner and slide it around the corner toward the left edge.
    • Take care cutting under the lower 2.5 inches (65 mm) of the left edge. Do not insert the opening pick more than 1/8 inches (3 mm) here. The display cables sit near this part of the bezel and are easily damaged. Once past the display cable area, do not insert the pick past the bezel.
    • Slide the pick along the left edge of the Surface to cut through the screen adhesive.
    • Leave this pick in the left edge to prevent the adhesive from resealing.
  10. Microsoft Surface Pro 5 Right Speaker Replacement: шаг 10, изображение 1 из 1
    • Reheat the iOpener and apply it to the top edge of the Surface's screen for two minutes.
    • The adhesive is thickest along this edge, and you may need to reheat and reapply the iOpener several times to get the Surface warm enough. Follow the iOpener instructions to avoid overheating.
  11. Microsoft Surface Pro 5 Right Speaker Replacement: шаг 11, изображение 1 из 3 Microsoft Surface Pro 5 Right Speaker Replacement: шаг 11, изображение 2 из 3 Microsoft Surface Pro 5 Right Speaker Replacement: шаг 11, изображение 3 из 3
    • Round the left corner with the opening pick and slide it along the top edge of the Surface. Stop when the pick is 2.75 inches (70 mm) away from the left edge.
    • The next 6 inches (15 cm) of the top edge of the case is covered by the left and right antennas, which sit between the case and the screen bezel. Follow the next steps carefully to avoid damaging the antennas.
  12. Microsoft Surface Pro 5 Right Speaker Replacement: шаг 12, изображение 1 из 3 Microsoft Surface Pro 5 Right Speaker Replacement: шаг 12, изображение 2 из 3 Microsoft Surface Pro 5 Right Speaker Replacement: шаг 12, изображение 3 из 3
    • Insert the point of a pick under the display where you just stopped cutting. Do not insert the pick deeper than the edge of the bezel.
    • Carefully roll the pick to the right, pressing the long edge of the pick into the screen adhesive underneath the bezel, cutting the adhesive as you go. Do not slide the pick along the edge of the Surface.
    • Keep the pick parallel to the screen throughout the whole procedure so that it doesn't catch on the antennas. Do not press the pick against the case.
    • Repeat this motion of inserting the point of the pick where you just cut, and rolling to the right all along the top edge of the Surface, until the pick is 2.5 inches (64 mm) from the right edge of the Surface.
  13. Microsoft Surface Pro 5 Right Speaker Replacement: шаг 13, изображение 1 из 3 Microsoft Surface Pro 5 Right Speaker Replacement: шаг 13, изображение 2 из 3 Microsoft Surface Pro 5 Right Speaker Replacement: шаг 13, изображение 3 из 3
    • Once you cut the adhesive over the antennas (8.5 inches, or 22 cm, away from the left edge), slide the pick the rest of the way along the top edge of the surface and round the top right corner to slice through any remaining adhesive.
  14. Microsoft Surface Pro 5 Right Speaker Replacement, Open the Surface: шаг 14, изображение 1 из 3 Microsoft Surface Pro 5 Right Speaker Replacement, Open the Surface: шаг 14, изображение 2 из 3 Microsoft Surface Pro 5 Right Speaker Replacement, Open the Surface: шаг 14, изображение 3 из 3
    • Very slowly lift the screen assembly away from the Surface case. If you encounter any resistance, stop and check that all the adhesive is separated.
    • Do not remove the screen yet. It is still connected to the motherboard by two cables.
    • Use an opening pick to cut through any remaining adhesive.
    • The flash lens may fall out of the Surface case. Keep track of the lens and return it to its cutout in the case during reassembly.
  15. Microsoft Surface Pro 5 Right Speaker Replacement: шаг 15, изображение 1 из 3 Microsoft Surface Pro 5 Right Speaker Replacement: шаг 15, изображение 2 из 3 Microsoft Surface Pro 5 Right Speaker Replacement: шаг 15, изображение 3 из 3
    • Lift the top of the screen assembly away from the case while sliding the bottom of the screen closer to the motherboard display connectors.
    • Gently lay the screen down on the case with the connectors facing up. Take care to avoid creasing the display cables.
  16. Microsoft Surface Pro 5 Right Speaker Replacement, Disconnect the screen: шаг 16, изображение 1 из 2 Microsoft Surface Pro 5 Right Speaker Replacement, Disconnect the screen: шаг 16, изображение 2 из 2
    • Use an opening pick to pry up one edge of the EMI shield covering the display board.
    • Repeat this procedure at different points around the shield until it is free.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
  17. Microsoft Surface Pro 5 Right Speaker Replacement: шаг 17, изображение 1 из 1
    • Lift the EMI shield away from the display board and remove it.
  18. Microsoft Surface Pro 5 Right Speaker Replacement: шаг 18, изображение 1 из 2 Microsoft Surface Pro 5 Right Speaker Replacement: шаг 18, изображение 2 из 2
    • Use the flat end of a spudger to pry the display interconnect cable straight up and out of its socket on the board.
  19. Microsoft Surface Pro 5 Right Speaker Replacement: шаг 19, изображение 1 из 2 Microsoft Surface Pro 5 Right Speaker Replacement: шаг 19, изображение 2 из 2
    • Insert one point of a pair of pointed tweezers into a gap in the edge of the EMI shield covering the digitizer connector.
    • Use the tweezers to pry the EMI shield away from the display as much as you can without bending it.
    • Repeat this procedure at different points around the shield until it is free. Remove the shield.
  20. Microsoft Surface Pro 5 Right Speaker Replacement: шаг 20, изображение 1 из 1
    • Pull the rest of the shield off of the digitizer connector and remove it.
  21. Microsoft Surface Pro 5 Right Speaker Replacement: шаг 21, изображение 1 из 2 Microsoft Surface Pro 5 Right Speaker Replacement: шаг 21, изображение 2 из 2
    • Use the tip of a spudger to pry the digitizer connector straight up and out of its socket on the screen.
  22. Microsoft Surface Pro 5 Right Speaker Replacement: шаг 22, изображение 1 из 1
    • Remove the screen assembly from the Surface.
    • During reassembly, pause here and follow this guide to replace the screen adhesive.
  23. Microsoft Surface Pro 5 Right Speaker Replacement, Disconnect the antenna support: шаг 23, изображение 1 из 2 Microsoft Surface Pro 5 Right Speaker Replacement, Disconnect the antenna support: шаг 23, изображение 2 из 2
    • Use the point of a spudger to pry the microphone connector straight up and out of its socket on the motherboard.
  24. Microsoft Surface Pro 5 Right Speaker Replacement, Unscrew the antenna support: шаг 24, изображение 1 из 1
    • Use a T5 Torx driver to remove the four screws securing the antenna support:
    • Three 4.5 mm screws
    • One 6 mm screw
  25. Microsoft Surface Pro 5 Right Speaker Replacement, Remove the antenna support: шаг 25, изображение 1 из 3 Microsoft Surface Pro 5 Right Speaker Replacement, Remove the antenna support: шаг 25, изображение 2 из 3 Microsoft Surface Pro 5 Right Speaker Replacement, Remove the antenna support: шаг 25, изображение 3 из 3
    • Use a spudger to lift the antenna support out of its recess in the Surface.
    • Remove the antenna support.
  26. Microsoft Surface Pro 5 Right Speaker Replacement, Disconnect the right speaker: шаг 26, изображение 1 из 2 Microsoft Surface Pro 5 Right Speaker Replacement, Disconnect the right speaker: шаг 26, изображение 2 из 2
    • Use the point of a spudger to lift the right speaker connector up and out of its socket on the motherboard.
  27. Microsoft Surface Pro 5 Right Speaker Replacement, Unscrew the speaker: шаг 27, изображение 1 из 1
    • Use a T5 Torx driver to remove the two screws securing the speaker:
    • One 6 mm screw
    • One 3.7 mm screw
  28. Microsoft Surface Pro 5 Right Speaker Replacement, Remove the speaker: шаг 28, изображение 1 из 3 Microsoft Surface Pro 5 Right Speaker Replacement, Remove the speaker: шаг 28, изображение 2 из 3 Microsoft Surface Pro 5 Right Speaker Replacement, Remove the speaker: шаг 28, изображение 3 из 3
    • Use a spudger to lift the left edge of the speaker so that it clears the components around the speaker.
    • With the left edge lifted, slide the speaker to the left, straight out of its recess in the case.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for troubleshooting help.
Sam Omiotek
Участник с: 02/25/19
72 866 Репутация
Автор 288 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 8
За всё время: 871
