Введение
If you need to replace the kickstand of your Microsoft Surface Pro 6, this guide will show you how.
The kickstand is the part of the tablet that allows it to be propped up. If it breaks or is damaged, you might want to replace it. It’s possible that your kickstand could become wobbly from overuse or if you drop it. The repair is not a difficult process, and you won’t have to take apart the actual Surface Pro 6. You’ll just have to remove and replace the kickstand itself.
Инструменты
Запчасти
Детали не указаны.
Remove the four 2.7 mm T3 screws—two on each side of the kickstand.
Remove the kickstand from the back cover.
Heute selbst durchgeführt. Hilfreich wäre, die Beschreibung um folgende Info zu ergänzen: wie man die Scharniere nach Schritt 4 wieder aus den Einbuchtungen im Gehäuse hochgestellt bekommt, um das neue Kickstand zu montieren. Nach eigenen Überlegungen konnte ich die Schaniere durch Einführen des benutzten Torx-Schraubenziehers in die äußere Schraubenbohrung des Scharniers und ganz behutsamen Hochdrücken des Scharniers mit Hilfe des Schraubenziehers lösen.
6 участников успешно повторили данное руководство.
Комментариев: 7
Any way to replace the hinges themself?
Also trying to find this out.
Thank you so much. I use the Surface 6 in portrait mode to read and use the kickstand as a grip/hand rest to prevent wrist strain. This meant the screws came loose constantly and I had to try and tighten them using my fingertip; not ideal. With the newly purchased Manta kit, and this guide, they are properly tightened again for the first time in over a year.
If you find that that the kickstand screws are still coming loose, I suggest applying a dab of blue Loctite (or nail polish if in a pinch) to the screws to help them hold in place.
The hinge mechanism has come completely loose so that the stand will not glide back into position. I thought it was the adhesive pads keeping it in place. Reading the instructions above, I now see that these pads can be put back into position. There is a whole Youtube showing the headaches of this kickstand hinge situation. The best bet is to buy a cover with a kickstand attached.
Thanks for the useless information on how to turn a screw! The hinges are broken! Why else would I be replacing the kickstand? The flap itself has no moving parts to break! How do you replace the hinges??? You've wasted my time and your own time writing the most obvious trash.
Wow, that sounds like such an annoying problem to have with your device! Unfortunately this guide only shows a walk-though for the stand itself. We don’t have a guide for that specific repair but we’d love if you made one! We rely on our amazing community members to help us complete our guide collections so that we can help everyone repair every thing. Head over to our Contribute page and click on “Create a new repair guide” to get started. If you follow the steps of our Surface Pro 6 Battery Replacement, it should get you pretty far into the repair. Good luck!!
