Введение
*In order to access the charging port, refer to steps 1 - 6 in the Microsoft Surface Pro Teardown Guide to remove the screen.
Teardown Guide
  1. Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro.
    • Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro.
  2. Use the plastic opening tool or fingers to pry out the front camera.
    • Use the plastic opening tool or fingers to pry out the front camera.
    • Lift the outside panel from the Surface Pro
    • Use the T5 torx screw driver to unscrew the 6 T5 screws in the left and right outside metal panels
    • Use the T2 torx screw driver to unscrew the 23 T2 screws on the left and right outside metal panels
    • Pull out left and right metal panels with hands
    • Pull out the orange charging port strip using tweezers
    • Unscrew the two T5 torx screws located on each side of the charging port.
    • Once you have unscrewed the charging port, you can gently pull it out with your hands.
Заключение
Jonathan Choi
Участник с: 09.10.2013
591 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 8-20, Regan Fall 2013 Member of Cal Poly, Team 8-20, Regan Fall 2013
CPSU-REGAN-F13S8G20
4 членов
Автор 10 руководств
Комментариев: 2
Where do you get a replacement charging port at?
Evil Robot - Ответить
Agree where can you get the port?
J-M. M. - Ответить
Просмотр статистики:
За 24 часа: 7
За 7 дней: 77
За 30 дней: 312
За всё время: 10,039
