Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
*In order to access the speakers, refer to steps 1 - 5 in the Microsoft Surface Pro Teardown Guide to remove the screen.
Выберете то, что вам нужно
Unscrew all the 23 screws located on the outside panel with the T5 torx screw driver
Use the T5 torx screw driver to unscrew the 6 T5 screws located on the left and right metal panels
Use the T2 torx screw driver to unscrew the 23 T2 screws located on the left and right metal panels
Disconnect the two speakers with tweezers
Gently pry out the speakers with spudger
Еще один человек закончил это руководство.
