Microsoft Wireless Laser Mouse 6000 and 5000 Disassembly
Выберете то, что вам нужно
  1. Microsoft Wireless Laser Mouse 6000 and 5000 Disassembly, Microsoft Wireless Laser Mouse 6000 and 5000 Disassembly: шаг 1, изображение 1 из 2 Microsoft Wireless Laser Mouse 6000 and 5000 Disassembly, Microsoft Wireless Laser Mouse 6000 and 5000 Disassembly: шаг 1, изображение 2 из 2
    • Remove the battery door and use a #8 Torx Tamper Proof Bit to remove the center screw. Pry the cover of the mouse starting from the back and lifting it up toward the wheel.
  2. Microsoft Wireless Laser Mouse 6000 and 5000 Disassembly: шаг 2, изображение 1 из 1
    • Remove the screw from the cover with a #1 Phillips. Unclip the two fins from the plate by lifting up on each gently. Remove the silver plate by prying the cover striaght up.
  3. Microsoft Wireless Laser Mouse 6000 and 5000 Disassembly: шаг 3, изображение 1 из 3 Microsoft Wireless Laser Mouse 6000 and 5000 Disassembly: шаг 3, изображение 2 из 3 Microsoft Wireless Laser Mouse 6000 and 5000 Disassembly: шаг 3, изображение 3 из 3
    • Gently lift up on the left shroud until it detaches. You can also detach the two side buttons. They are compression fit. Pry them each gently out of the hinge with a flat blade.
    Thanks for publishing this. I found what was casing my mouse wheel to drag . Looks like the rubber on the outside of the wheel is frayed and dragging against the supporting frame for the wheel. Just need to see how to trim off the outer rubber.
    Greg Magyar - Ответить
  4. Microsoft Wireless Laser Mouse 6000 and 5000 Disassembly: шаг 4, изображение 1 из 2 Microsoft Wireless Laser Mouse 6000 and 5000 Disassembly: шаг 4, изображение 2 из 2
    • Be Extremely Careful There is a small spring between the housing and the base plate of the mouse. The ribbon cable that attachs the mouse wheel is tough to remove. It is compression fit without tabs. I needed to use a small flat blade screw driver to pry it out of the socket. The mouse wheel housing that clicks to the left and right is compression fitted on the bottom only. You can separate it from the other housing by lifting up on the bottom "hinge". The bottom housing is again a compression fit hinge attaching it to the base plate with spring.
  5. Microsoft Wireless Laser Mouse 6000 and 5000 Disassembly: шаг 5, изображение 1 из 3 Microsoft Wireless Laser Mouse 6000 and 5000 Disassembly: шаг 5, изображение 2 из 3 Microsoft Wireless Laser Mouse 6000 and 5000 Disassembly: шаг 5, изображение 3 из 3
    • The mouse wheel assembly comes apart easily.
  6. Microsoft Wireless Laser Mouse 6000 and 5000 Disassembly: шаг 6, изображение 1 из 1
    • The circuit board is all one piece that lifts straight out. As you lift out the circuit board push the battery terminals so they clear the base plate. The reset pin will come loose after the circuit board is removed.
  7. Microsoft Wireless Laser Mouse 6000 and 5000 Disassembly: шаг 7, изображение 1 из 2 Microsoft Wireless Laser Mouse 6000 and 5000 Disassembly: шаг 7, изображение 2 из 2
    • Cleaning Time! Now all the plastic parts are separated you can clean them. I used a crest spin brush with simple green. Spray the large parts and then brush and rinse in the sink. For the smaller parts spray and brush over a container and then rinse in water in another container. Let all the parts air dry and use compressed air for the small parts before reassembling.
Заключение
8 участников успешно повторили данное руководство.
DoesGoodJob Tech
Участник с: 05/27/10
257 Репутация
1 руководство автора
10 Комментариев
Very thorough, thanks, but would like to offer a simple alternative that may apply. After several years, my MLM 5000 scroll wheel became very difficult to turn; thought I'd have to disassemble and clean it. Actually, the rubbery plastic coating on the wheel was shredding and rubbing against the outer casing, so I pried up a section of the coating with a small screwdriver, cut through its width with cuticle scissors, and peeled/rolled it off the wheel completely. The scroll wheel is now PERFECTLY smooth -- better than it ever was or than ANY other mouse I ever tried. Really love the feel of it now. And without the extra padding, my index finger now rests 1 or 2 mm lower, which I find a little more comfortable. The only drawback is with the slightly reduced height, it's very minimally more difficult to scroll horizontally (tilt scroll). The resistance is unchanged, but there's that much less surface to push against horizontally. Vertical scrolling (rolling) is great now.
mlm5000 - Ответить
Great advice from @mlm5000. Just rip off the rubber wheel cover!
Mat Kramer -
Don't do this!! My wheel does not work at all now!
Doug Webste -
This looks nothing like my Microsoft 5000 mouse.
Doug Webste -
I also ripped off the shredding wheel cover. It works fine, however, it is painful to use. There are raised edges on either side of the wheel that poke into my finger. For now, I am wearing a fingertip protector, however it is not optimal.
Techmom236 -
Thanks. Very helpful. For me, the first screw is a T9 Torx, not T8.
mattadata - Ответить
Many thanks. Just used this guide to fix a "Microsoft Wireless Laser Mouse 6000" (May 2007 model, came as part of a keyboard and mouse set).
The mouse had refused to work, no cursor movement, no clicks registering, nothing.
Tried re-syncing with the receiver, no difference. Changed batteries, no difference.
Also tried viewing the laser through an LCD screen via the camera on a phone to see if it was functioning, which it wasn't (usually it will show up as a pinpoint blue light - be careful when doing this not to look directly at the laser but at an angle, you should be able to see a neony blue LED like light through the laser 'port' / hole if it's working).
Literally on the verge of throwing the mouse out and I decided to take it apart completely just to see if there were any obvious loose components or connections.
So, followed this guide... nothing obviously loose although the laser unit did seem slightly ill-fitting... but after putting it back together, hey presto... it worked!
Many thanks. :)
Munk Pad - Ответить
One other thing - on my model, the fascia of the mouse has become extremely sticky to the point of being very uncomfortable to use. AT first I thought it was airborne grease (no idea why it would be that but that's what it felt like, tacky), but in the end I came to the conclusion that it was a rubber coating they'd applied to some of the surfaces of the mouse to make it more tactile.
To get rid of the rubber coating I just applied some detergent and scrubbed it off gently with a steel wool pad. The rubber came off no problem... the surface is slightly scratched but for a 7 year old mouse I can live with that, it actually doesn't feel that bad to the touch when you have it in your hand anyway.
Munk Pad -
I had the issue with the rubber coating as well. I thought I had spilled something on it in my bag. Thanks for the tip! The slime came off great with a little coaxing.
Another point about this mouse. Has anyone had any issues with the wheel button failing? You don't realise how much you miss middle-click until it's gone!
Gareth Elsby -
Thanks for the guide.
BTW on the 5000 the whole top is a single assembly removed by lifting the rear a little then sliding backwards. My mouse the rubber on the wheel was so worn it was rubbing on the plastic wheel cover. I fixed it by removing the rubber. Works fine.
tlynnch - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 11
За последние 30 дней: 62
За всё время: 83,128
