Введение
Use the guide to replace both or one of your broken or wasted thumbsticks in your Xbox Series X controller.
The thumbsticks are the central part of the controller that allows for most of your in-game movement. A wasted or broken thumbstick could reduce your performance for some of your favorite games.
Before using this guide, make sure to ensure that your thumbsticks are the ones wasted or broken because if it is stick drift, then this is not the correct guide for you to follow.
Выберете то, что вам нужно
Remove the battery pack cover.
If there are any batteries inside of it, remove them.
Place an iFixit opening tool between the seam of both the front and side plates.
Move the tool repeatedly along the seam between the two plates until the side plate is wholly disconnected from the front plate.
Remove or pick a hole on the warranty sticker label to reveal the center screw.
Remove all five screws from the backplate using a TR8 Torx screwdriver.
14 участников успешно повторили данное руководство.
4 Комментариев
@aaron73239 , to fix the joystick drift, you might want to try this guide.
Perhaps it is this article? Xbox One Wireless Controller Model 1708 Button Replacement
Would be appreciated if someone with relevant knowledge or experience would confirm this.
Pictory -
