Microsoft Zune 80 Battery Replacement
Выберете то, что вам нужно
  1. Microsoft Zune 80 Battery Replacement, Case: шаг 1, изображение 1 из 1
    • Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
  2. Microsoft Zune 80 Battery Replacement: шаг 2, изображение 1 из 1
    • There are two T3 screws under the cap. Remove both with a T3 screwdriver.
    • Be careful with removing these screws! These screwheads are prone to breaking.
  3. Microsoft Zune 80 Battery Replacement, Remove the Casing: шаг 3, изображение 1 из 2 Microsoft Zune 80 Battery Replacement, Remove the Casing: шаг 3, изображение 2 из 2
    • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
    • Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
  4. Microsoft Zune 80 Battery Replacement, Remove the Silver Tape: шаг 4, изображение 1 из 2 Microsoft Zune 80 Battery Replacement, Remove the Silver Tape: шаг 4, изображение 2 из 2
    • Remove the silver tape from the bottom center and the top right. This allows access to the hard drive and the battery.
  5. Microsoft Zune 80 Battery Replacement: шаг 5, изображение 1 из 3 Microsoft Zune 80 Battery Replacement: шаг 5, изображение 2 из 3 Microsoft Zune 80 Battery Replacement: шаг 5, изображение 3 из 3
    • Unclick the black bar connecting the orange hard drive cable to the bottom of the hard drive. Gently push towards the bottom of the device on the black bar until you hear a click sound, it is now disengaged from the hard drive.
    • If the cable doesn't come off easily, the black bar has not been un-clicked.
    • The hard drive cable (ZIF cable) is very fragile. Try to keep it in its original shape and bend it as little as possible.
    • Now gently pull the orange hard drive cable to remove it from the hard drive.
    • Lift the hard drive from the device.
    • Hard Drive Replacement Only: Check to make sure the hard drive cable is in good condition and then connect the new hard drive in the same place, following the steps in reverse order.
  6. Microsoft Zune 80 Battery Replacement, Battery: шаг 6, изображение 1 из 2 Microsoft Zune 80 Battery Replacement, Battery: шаг 6, изображение 2 из 2
    • Remove two more pieces of silver tape from the bottom of the device. One of these pieces is below the other.
  7. Microsoft Zune 80 Battery Replacement: шаг 7, изображение 1 из 1
    • Remove the two T4 screws holding the headphone jack receiver on the top left corner of the device.
  8. Microsoft Zune 80 Battery Replacement: шаг 8, изображение 1 из 2 Microsoft Zune 80 Battery Replacement: шаг 8, изображение 2 из 2
    • Remove the two T4 screws holding the metal brackets on both sides of the bottom of the device.
    • Remove the screws, brackets, and clips from the device. These are small pieces, so put them in a safe place.
  9. Microsoft Zune 80 Battery Replacement: шаг 9, изображение 1 из 1
    • The orange audio board cable is clipped in with a small black bar, same as the hard drive cable. Un-clip the bar by pushing upwards on the edge of the black bar towards the orange cable. You will hear it click when is disengages.
    • WARNING: If the cable doesn't come off easily, the black bar has not been un-clicked.
  10. Microsoft Zune 80 Battery Replacement: шаг 10, изображение 1 из 1
    • Flip the black bar to unclip the left side of the hard drive cable. You can now remove the hard drive cable.
  11. Microsoft Zune 80 Battery Replacement: шаг 11, изображение 1 из 2 Microsoft Zune 80 Battery Replacement: шаг 11, изображение 2 из 2
    • Remove the two T4 screws that hold the charging port on the bottom of the device.
    • Remove the charging port.
  12. Microsoft Zune 80 Battery Replacement: шаг 12, изображение 1 из 3 Microsoft Zune 80 Battery Replacement: шаг 12, изображение 2 из 3 Microsoft Zune 80 Battery Replacement: шаг 12, изображение 3 из 3
    • Remove the battery from the device with the cables still connected.
    • Carefully lift up the mother board located at the base of the Zune. Unclip the orange ribbon cable in the same manner as in the previous steps.
    • Remove the mother board from the Zune, leaving the black wire connected.
Заключение
21 участников успешно повторили данное руководство.
koolkid
Участник с: 10/28/09
499 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 6-5, Maness Fall 2009 Участник Cal Poly, Team 6-5, Maness Fall 2009
CPSU-MANESS-F09S6G5
5 членов
Автор 5 руководств
9 Комментариев
Where can you get a zune battery? Model 1376 120GB
Evan Freach - Ответить
Where can you get a battery?
Ethan Leroux - Ответить
changing email and passwords are bad at the same time
nutcase too - Ответить
On the 120 GB model, the cap in Step 1 is one complete unit. You should follow step 2 first.
scheppdogg532 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 13
За последние 7 дней: 67
За последние 30 дней: 276
За всё время: 44,137
