Введение
Unable to raise or lower the volume? Replace the controls sidebar and restore balance to the force.
Выберете то, что вам нужно
Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
Slightly rotate the top edge of the upper rear panel away from the Zune.
Lift the upper rear panel straight up off the black plastic lower rear panel.
Use a Zune opening tool to gently lift the media button lever off the post cast into the inner chassis.
Еще один человек закончил это руководство.
