Введение
In this guide, we will be replacing the thermal component of a Midea WHJ1705B Electric Kettle.
As an electric kettle begins to lose control of its temperature, more often than not it will begin experiencing problems of all kinds. If you notice this problem occurring in your own electric kettle, then rest assured that you have come to the right place! Finding spare parts for electric kettles can be difficult, so having a DIY solution (such as the one we use here) is crucial to repairing kettles such as this one.
Please unplug the kettle before beginning the repair process.
Выберете то, что вам нужно
Use a T5 [Torx] screwdriver to remove the three screws from the base, and remove the bottom cover.
Use a pair of needle-nose pliers to unplug the power cord at both ends of the heat pipe
Use a Phillips #0 screwdriver to remove the three screws on the left, right, and bottom that are attached to the assembly.
Use a pry tool or sharp object to pry off the plastic frame holding the assembly.
Apply a small dab of thermal silicone approximately the size of a coin to the new assembly.
Repeat on the opposite side using the thermal silicone.
Use a Phillips #0 screwdriver to secure the new assembly into place with the three Phillips screws.
Retrieve the three Torx T5 screws to secure the base.
Use the T5 [Torx] screwdriver to reattach the base to the assembly.
Congrats! If you have followed all the steps correctly then you have successfully managed to replace the thermal component on your electric kettle! To reassemble your device, refer back to steps 7-9.
2 участников успешно повторили данное руководство.
