Midland X-tra Talk Radio LXT118 Antenna Replacement
Выберете то, что вам нужно
  1. Midland X-tra Talk Radio LXT118 Antenna Replacement, Batteries: шаг 1, изображение 1 из 2 Midland X-tra Talk Radio LXT118 Antenna Replacement, Batteries: шаг 1, изображение 2 из 2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Midland X-tra Talk Radio LXT118 Antenna Replacement: шаг 2, изображение 1 из 1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Midland X-tra Talk Radio LXT118 Antenna Replacement, Case: шаг 3, изображение 1 из 1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Midland X-tra Talk Radio LXT118 Antenna Replacement: шаг 4, изображение 1 из 1
    • Detach back part of the case by gently lifting up.
  5. Midland X-tra Talk Radio LXT118 Antenna Replacement, Antenna: шаг 5, изображение 1 из 1
    • Carefully and slowly lift the motherboard away from the front case. The motherboard will be attached to the speaker, which is firmly glued onto the front case.
  6. Midland X-tra Talk Radio LXT118 Antenna Replacement: шаг 6, изображение 1 из 1
    • Check the connection of the antenna with your eyes and fingers. The connection should be firm and smooth where it was soldered.
    • Ensure that the spring of the antenna isn't crooked or damaged by rubbing your fingers along the length of the spring.
    • Desolder the connection of the antenna to the motherboard. Careful!, if used improperly, the soldering tool can damage the circuit board!
  7. Midland X-tra Talk Radio LXT118 Antenna Replacement: шаг 7, изображение 1 из 1
    • After obtaining a new or undamaged spring, solder it back onto the circuit board. Again, this is a delacate process as the soldering tool will be hot!
Заключение
5 участников успешно повторили данное руководство.
Andre Nguyen
Участник с: 01/18/13
108 Репутация
1 руководство автора
Команда
Cal Poly, Team 19-43, Regan Winter 2013 Участник Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 членов
Автор 9 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 21
За всё время: 2,082
