Введение
It will be necessary to solder the wire connection in order to properly complete this installation.
Выберете то, что вам нужно
Remove the old or broken circuit board from the front case by carefully separating it from the back.
Clip the red and black wires at the base of the motherboard to completely separate it from the radio case. You should have 2 separate pieces.
Reattach the speaker wires and antenna to the new circuit board using a soldering iron. Take caution when using the hot soldering tool!
2 участников успешно повторили данное руководство.
