Midland X-tra Talk Radio LXT118 Front buttons Replacement
Выберете то, что вам нужно
  1. Midland X-tra Talk Radio LXT118 Front buttons Replacement, Batteries: шаг 1, изображение 1 из 2 Midland X-tra Talk Radio LXT118 Front buttons Replacement, Batteries: шаг 1, изображение 2 из 2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Midland X-tra Talk Radio LXT118 Front buttons Replacement: шаг 2, изображение 1 из 1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Midland X-tra Talk Radio LXT118 Front buttons Replacement, Case: шаг 3, изображение 1 из 1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Midland X-tra Talk Radio LXT118 Front buttons Replacement: шаг 4, изображение 1 из 1
    • Detach back part of the case by gently lifting up.
  5. Midland X-tra Talk Radio LXT118 Front buttons Replacement, Front buttons: шаг 5, изображение 1 из 1
    • Once the back case is already off, use your fingers to lift up the circuit board from the side opposite the antenna.
  6. Midland X-tra Talk Radio LXT118 Front buttons Replacement: шаг 6, изображение 1 из 1
    • Lay the circuit board down on the side, as you will not want it interfering with your work on the buttons!
  7. Midland X-tra Talk Radio LXT118 Front buttons Replacement: шаг 7, изображение 1 из 1
    • Grasp the rubber cast around the buttons from one side, and slowly lift upwards. Make note of which way the buttons fit into the plastic casing!
    • At this point, the buttons can be cleaned in accordance with the radio buttons are stuck or sticking troubleshooting guide.
    • The speaker does not need to removed in order to get to the buttons.
Заключение
2 участников успешно повторили данное руководство.
Logan
Участник с: 01/17/13
282 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 19-43, Regan Winter 2013 Участник Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 членов
Автор 9 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 1,025
