Midland X-tra Talk Radio LXT118 Speaker Replacement
Выберете то, что вам нужно
  1. Midland X-tra Talk Radio LXT118 Speaker Replacement, Batteries: шаг 1, изображение 1 из 2 Midland X-tra Talk Radio LXT118 Speaker Replacement, Batteries: шаг 1, изображение 2 из 2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Midland X-tra Talk Radio LXT118 Speaker Replacement: шаг 2, изображение 1 из 1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Midland X-tra Talk Radio LXT118 Speaker Replacement, Case: шаг 3, изображение 1 из 1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Midland X-tra Talk Radio LXT118 Speaker Replacement: шаг 4, изображение 1 из 1
    • Detach back part of the case by gently lifting up.
  5. Midland X-tra Talk Radio LXT118 Speaker Replacement, Speaker: шаг 5, изображение 1 из 1
    • Remove the circuit board from the front part of the radio case.
    • Clip the red and black connecting wires at the base closest to the circuit bored in the spots denoted by the two red circles.
  6. Midland X-tra Talk Radio LXT118 Speaker Replacement: шаг 6, изображение 1 из 1
    • Scrape off the glue on the outer lining of the speaker using the metal spudger.
  7. Midland X-tra Talk Radio LXT118 Speaker Replacement: шаг 7, изображение 1 из 1
    • Pry the speaker from the case using the metal spudger.
    • This should not take excessive force, so make sure all remaining glue is scraped off from the edges if it will not easily come out.
  8. Midland X-tra Talk Radio LXT118 Speaker Replacement: шаг 8, изображение 1 из 1
    • The speaker is now disassembled!
  9. Midland X-tra Talk Radio LXT118 Speaker Replacement, Speaker: шаг 9, изображение 1 из 1
    • Solder the new wires to the circuit board in the spots denoted by the two red circles.
  10. Midland X-tra Talk Radio LXT118 Speaker Replacement: шаг 10, изображение 1 из 1
    • Place the speaker back inside the shell casing in the same way that it was originally placed.
    • Accurately use a polyurethane glue around the rim of the speaker to mount it firmly back inside the plastic casing.
Заключение
2 участников успешно повторили данное руководство.
James Tucker Dunn
Участник с: 01/18/13
371 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 19-43, Regan Winter 2013 Участник Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 членов
Автор 9 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 14
За последние 30 дней: 18
За всё время: 776
