Введение
Looks as though some experience with a soldering tool may be necessary, so make sure to be safe with these steps!
Выберете то, что вам нужно
First, apply pressure with your thumb on the top of the battery cover.
Next, pull down on the cover until it begins to slide.
Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
Remove the circuit board from the front part of the radio case.
Clip the red and black connecting wires at the base closest to the circuit bored in the spots denoted by the two red circles.
Solder the new wires to the circuit board in the spots denoted by the two red circles.
Place the speaker back inside the shell casing in the same way that it was originally placed.
Accurately use a polyurethane glue around the rim of the speaker to mount it firmly back inside the plastic casing.
2 участников успешно повторили данное руководство.
