Введение
Do you know what happens when your grinder overheats? If not, this is a quick guide on how to change the ball bearings. A ball bearing is a ring consisting of small solid metal balls between a wheel and a fixed axle, in which the rotating parts and stationary parts are separated to reduce friction. A damaged or worn ball bearing will reduce the performance of your grinder and ultimately destroy it completely.
Выберете то, что вам нужно
Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
Lift the trigger assembly off of its mount.
Dispose of the old trigger assembly and install the new one.
Using a Torx T20 screwdriver to remove four 6mm screws located on top of the gearcase assembly.
Using a 3/8 Wrench, Remove the nut located in the center of the Gearcase.
The nut and pinion should immediatley come apart from the rotor assembly.
Using a Torx T15 screwdriver, remove the two 4mm screws to take the bearing retainer off.
Use a hammer to knock out the bearing and begin installing the new one before reassembling.
Еще один человек закончил это руководство.
