Введение
When using the Milwaukee 2630-20, the gearcase acts as a shield, protecting you from flying debris and wood. Damage to the upper gearcase can potentially cause a risk in performance problems, damage with prolonged use, and a risk to the safety of the user. If there is damage or chipping to the upper gearcase with exposure to the blade, please refer to this guide to replace the upper gearcase.
Выберете то, что вам нужно
Remove three 8 mm screws from the top of the upper gearcase using a Torx T6 screwdriver.
Carefully remove the upper gearcase with your hand and replace it with a new one.
Еще один человек закончил это руководство.
