Введение
This guide will demonstrate how to replace the Trigger Assembly on the Milwaukee Hex Impact Driver 2656-20. The First Two steps will cover disassembly of the drill. The only tool required for this repair is a T-10 Torx Screwdriver. The repair is considered Difficult in difficulty and will take approximately 20 minuets.
Выберете то, что вам нужно
Squeeze the red buttons on the battery.
While squeezing the red buttons, slide the battery forward and out to remove it from the device.
Lay the impact driver on its side.
Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
Separate the two halves by pulling up on the top half.
Lay the top half to the side.
Remove the two 6 mm screws on the back of the brush card assembly using the T10 Torx screwdriver.
Move the two wires out of the way.
