Введение
The following repair guide shows how to remove and replace the output shaft bearing in an Milwaukee Hex Impact Driver 2750-20.
Выберете то, что вам нужно
Remove the five T9 15.5 mm screws.
Remove the single T9 19.5mm screw.
Remove the two T9 37mm screws.
Once the interior is open locate the output shaft driver pictured at the left of the screen.
Lift the driver head and motor assembly directly out of the outer casing.
Pull the driver head away from the motor assembly, separating the two.
