Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement
Выберете то, что вам нужно
  1. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement, Milwaukee Hex Impact Driver 2753-20 Cover Removal: шаг 1, изображение 1 из 1
    • Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
    • Remove the two 40 mm Torx T10 screws near the bottom of the cover.
  2. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: шаг 2, изображение 1 из 2 Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: шаг 2, изображение 2 из 2
    • Carefully remove the cover.
    • If there is buildup from sawdust or sediment it might be a little difficult to take apart.
  3. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement, Gear Case: шаг 3, изображение 1 из 1
    • Set the cover aside so the drill body is visible and can be accessed.
    • The gear case is the silver cylinder part with a black tip in the top of the drill.
  4. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: шаг 4, изображение 1 из 2 Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: шаг 4, изображение 2 из 2
    • Grip the gear case in one hand while holding the body of the drill with the other.
    • Pull outward to remove.
    • Remove carefully, being mindful of the connecting wires. Damage to these wires can cause permanent damage to the drill.
  5. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: шаг 5, изображение 1 из 1
    • Check the connection from the motor to the trigger.
    • Check that the connection to the circuit board is intact.
    • If both connections are intact, the gears inside the gear case assembly may be jammed and need to be replaced.
  6. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: шаг 6, изображение 1 из 1
    • A replacement part can be found on the Milawukee Tool Website under Part NO. 14-30-D012.
Заключение
Kaylee Rose
Участник с: 01/16/19
268 Репутация
Автор 3 руководств
Команда
University of Alabama, Team S2-G3, Bedsole Spring 2019 Участник University of Alabama, Team S2-G3, Bedsole Spring 2019
UA-BEDSOLE-S19S2G3
3 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 18
За всё время: 1,645
