Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement
Выберете то, что вам нужно
  1. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: шаг 1, изображение 1 из 3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: шаг 1, изображение 2 из 3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: шаг 1, изображение 3 из 3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device, making the gray part face to the right.
    • Remove four 14mm screws using a T20 Torx screwdriver.
    • Remove four 18mm screws using a T20 Torx screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: шаг 2, изображение 1 из 3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: шаг 2, изображение 2 из 3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: шаг 2, изображение 3 из 3
    • Hold the device so the gearbox assembly faces directly towards you.
    • Remove the four screws using a T20 Torx screwdriver.
    • Using a plastic opening tool, pry the gearbox assembly away from the clam shell.
  3. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: шаг 3, изображение 1 из 1
    • After all necessary screws are removed, gently remove the upper red cover from the device.
    • Remove the gray motor and gearbox assembly.
    • Remove the gearbox gently as to not damage the brushes.
  4. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: шаг 4, изображение 1 из 3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: шаг 4, изображение 2 из 3 Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: шаг 4, изображение 3 из 3
    • Attach a bearing removal tool to the bearing.
    • Tighten the bearing puller until the bearing comes off of the motor shaft.
    • For easier removal, lightly heat the bearing with a propane torch.
    • Heat and then press the replacement bearing onto the shaft.
Заключение
Yuna Choi
Участник с: 09/18/19
387 Репутация
Автор 3 руководств
Команда
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 5
За последние 30 дней: 16
За всё время: 599
