Введение
If you need to replace the gearbox on your Milwaukee M18 2606-20 cordless power drill (the drill slips and loses torque to turn anything) see this guide on how to remove it. The gearbox is what controls the speed and torque of the drill. Removing some of the parts could require a bit of strength so keep this in mind.
Выберете то, что вам нужно
Rotate the chuck counterclockwise as far as possible to loosen from the base.
Remove the 28 mm inner screw holding the chuck onto the drill using a Phillips #3 screwdriver.
Rotate the screw clockwise to loosen it.
Using the T3 Torx screwdriver, remove the seven 18 mm screws from the handle area of the case.
Using the T3 Torx screwdriver, remove the two 21 mm screws from the top of the case.
Using the T3 Torx screwdriver, remove the four 20 mm screws from the front of the case.
Open the case by sliding the opening tool all the way around the case to pry it apart.
Lift the gearbox slightly and pull away from the motor to remove it from the case .
Еще один человек закончил это руководство.
