Введение
In the event that the flash is not working properly due to internal issues and not settings, it is possible to replace the capacitor to restore function to the flash.
Выберете то, что вам нужно
Then, carefully pry apart the front and back outer casing away from the internal components.
On the front side of the camera, locate the flash battery holder.
Lift the housing and remove the battery.
After removing the battery, clip the wires and solder the replacement battery.
Еще один человек закончил это руководство.
