Введение
The flashbulb and casing are one component located at the top of the camera. A replacement will be the whole component and not each of the parts separately.
Выберете то, что вам нужно
Then, carefully pry apart the front and back outer casing away from the internal components.
Remove 2mm screws connecting the flash housing to the main components of the camera.
Use the spudger to push the black plastic hooks through the circuit board to release the flash housing.
Once the screws have been removed, pull the circuit board away from the body of the camera.
Pull the housing away from the circuit board.
To reassemble device, follow steps in reverse order. This will require the reattachment of wires from the camera to the flashbulb casing.
