Minolta X-370 Battery Replacement
Выберете то, что вам нужно
  1. Minolta X-370 Battery Replacement, Minolta X-370 Battery Replacement: шаг 1, изображение 1 из 2 Minolta X-370 Battery Replacement, Minolta X-370 Battery Replacement: шаг 1, изображение 2 из 2
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Minolta X-370 Battery Replacement: шаг 2, изображение 1 из 1
    • Remove the batteries, making sure to note their proper alignment.
    Hi just checking which type of batteries are required? You have two types listed, the SR44/LR44 (I understand those are the same types of batteries) then the CR-1 / 3 /3N 3V battery? How many batteries do I need and which type will I need? thanks!
    Juliette Perry-Dumarquez - Ответить
Заключение
4 участников успешно повторили данное руководство.
Nick
Участник с: 04/19/11
525 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 8-7, Regan Spring 2011 Участник Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 членов
Автор 8 руководств
Один комментарий
Hi there, i'm a bit stuck, in my 35mm SLR i was taking a shot and the batteries died, leaving the mirror stuck in the up position, i've changed the batteries and the release for the shutter won't click, i can't advance the film lever and so it's a sitting duck at the moment. They're brand new batteries but because the mirror is up i can't even see if the metering works. because i'm half way through a roll of film i don't want to open the back and ruin it so i'm wondering if there's any way to get the shutter to release again or to get the mirror back down, i don't mind loosing a few blank exposures but again i really wouldn't want to ruin the film. Many thanks and i hope you can get back to me,
Cameron
Cameron Tyson - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 33
За последние 30 дней: 126
За всё время: 20,565
