Введение
Before you start the replacement process, make sure that you have the proper repair tools, a Philips PH0 head and tweezers. You should be careful not to exert too much pressure/force on the components.
This guide will be able to walk you through the steps to replace your Mio ALPHA 2's motherboard.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove the four 3.8mm JIS #00 screws from the motherboard.
Remove the motherboard with tweezers
