Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale)
Выберете то, что вам нужно
  1. Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Identify your Revision: шаг 1, изображение 1 из 1
    • You can find the Version Number of your MMCS printed on the top right corner of the unit.
    • In this case the Version Number is W-12.
  2. Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Download the System Files: шаг 2, изображение 1 из 2 Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Download the System Files: шаг 2, изображение 2 из 2
    • You can download the map data files here: Europe and Russia
    • Press on SHOW ALL.
    • Download the SYS_##_###.whx file containing the version number of your device in its title.
    • MMCS E-11 and E-12 are analogues of W-13.
  3. Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Download the Map Data: шаг 3, изображение 1 из 2 Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Download the Map Data: шаг 3, изображение 2 из 2
    • Download the last MAP_20##A_##.whx file in the list.
  4. Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Insert the SD Card: шаг 4, изображение 1 из 1
    • The SD Card has to be a 16GB SDHC card with at least 15.718.400.000 Bytes and 30.700.000 Logic Sectors.
    • If the SD Card you have is a bit too small, but you have larger one on hand, you can also just flash to the larger one, format the smaller one to exFAT at 512 Bytes per sector and copy all the files over from the larger one. This might lead to some instability, but still works.
    • Insert the SD Card into your PC.
    • Launch WinHex as Administrator.
    • Right click on winhex.exe and choose Run as Administrator.
    • Since the image files are uncompressed, you can also write them with dd, though this guide will only cover the process using WinHex.
  5. Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Write the Map Data: шаг 6, изображение 1 из 3 Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Write the Map Data: шаг 6, изображение 2 из 3 Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Write the Map Data: шаг 6, изображение 3 из 3
    • In WinHex, choose File > Restore Image.
    • Choose the MAP_20##A_##.whx file you downloaded in Step 3.
    • Choose the Physical Storage Volume (SD Card) you want to flash.
    • Make sure that you are flashing to the correct Physical Volume! Flashing to your hard drive will break your operating system!
    • Confirm by pressing OK.
    • This might take a while depending on the speed of the SD card you selected.
    • Repeat the previous step with the SYS_EU_###.whx file for the System area.
    • Close WinHex.
    • Safely eject the SD Card.
  6. Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Check the SD Card: шаг 8, изображение 1 из 2 Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Check the SD Card: шаг 8, изображение 2 из 2
    • Reconnect the SD Card to your PC and check the files on it.
    • If the file names are a garbled mess, as shown in the second image, you need to reformat and reflash the SD Card. Closing WinHex, ejecting and reconnecting the SD Card between steps 5 and 6 might help. In some cases it might also help to format the SD Card to NFTS before flashing.
  7. Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Flip up the Display: шаг 9, изображение 1 из 2 Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Flip up the Display: шаг 9, изображение 2 из 2
    • Press the OPEN-Button.
    • Press the Monitor OPEN-Button on the screen.
  8. Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Swap the SD Card: шаг 10, изображение 1 из 2 Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Swap the SD Card: шаг 10, изображение 2 из 2
    • Swap the SD Card with the one already installed in the MAP-Slot.
    • Close the display by pressing the OPEN-Button again.
    • If the car accepts the SD Card it will now be permanently paired to the MMCS and no longer work with any other car or show up on a computer.
    • If the firmware on the SD Card is newer than the version already installed the Unit will ask you if you want to update. Press the Update-Button on the screen to proceed.
    • If you were already on the newest firmware version, the car will normally at most run a short update sequence after you restart the car.
    • Do not turn off the ignition while the update is running!
    • If you are switching from the Russian to the European interface or vice versa, the unit might tell you that it can’t read the Map card data. The following steps will only apply if you are encountering this problem.
  9. Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Enter the Service Menu: шаг 12, изображение 1 из 3 Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Enter the Service Menu: шаг 12, изображение 2 из 3 Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Enter the Service Menu: шаг 12, изображение 3 из 3
    • Enter the Service Menu by pressing and holding the SETTINGS and MAP-Buttons (for W-16 & W-17 INFO/SET and SEEK) for 4 seconds.
  10. Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Navigate the Service Menu: шаг 13, изображение 1 из 2 Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Navigate the Service Menu: шаг 13, изображение 2 из 2
    • Navigate to Versions Indication.
    • Long-press Navi (Application) for 4 seconds.
  11. Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Update the Unit: шаг 14, изображение 1 из 3 Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Update the Unit: шаг 14, изображение 2 из 3 Mitsubishi MMCS NR-242 Map Data Card Update (WinHex Image, European and Russain locale), Update the Unit: шаг 14, изображение 3 из 3
    • Press Update from Map Card.
    • Confirm by pressing on Update.
    • The Unit will now start the update process. In this process it will reboot twice and reset itself back to factory settings.
    • Do not turn off the car while the update is running!
Заключение
Make sure you keep the old SD Card as a backup, just in case anything ever happens to the new one.
5 участников успешно повторили данное руководство.
Sebastian
Участник с: 08/19/18
21 643 Репутация
Автор 60 руководств
Команда
German Translators Участник German Translators
Community
29 членов
Автор 768 руководств
24 Комментариев
THANKS ,
for your support
yes I did step 5 and 6 but I was not on the physical media
it was my mistake
after that you had to do step 7 format in NFTS
on the other hand in NFTS format of the SD16GB card has less than 15,718,400,000
thanks I have to give it a try in the car
Ps, being French I made an error in the email received from support
I accidentally unsubscribed from sending emails
how can I reactivate it
jolilo - Ответить
Thank you updated card
in my 2023-A vehicle
Sincerely
jolilo - Ответить
after inserting the card it just pops up for a second that update and then it says error about the card and it's data. any idea how to fix this?
Mike - Ответить
Continuing from step 12 onwards could help. If that doesn't work you can also try [недействительная ссылка на руководство].
Alfred Kwak -
yes but the problem is exactly from step 12 forward, I can put the card in and star the actions etc. but on step 14 trying to finish the update it just gives error about the data and it will not continue, all I can do is change back the original SD (which has maps from 2014) and that will still work... so any idea what might be the cause?
Mike -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 24
За последние 7 дней: 175
За последние 30 дней: 990
За всё время: 9,268
