Введение
Use this guide to install a new power supply.
Выберете то, что вам нужно
Remove the following 8 Phillips #1 screws:
One 22 mm Phillips #1 in the bottom right corner of the back panel.
One 18 mm Phillips #1 in the top middle of the back panel.
Six 18 mm Phillips #1 in the rest of the back panel.
Pull the back panel off of the television by gripping the sides and rotating it down.
Remove the four 10 mm black Phillips #1 screws with fine thread that attach the protective case to the TV.
Disconnect the lamp ballast power connection and the light engine power connection by pressing down the tab and pulling out the connection.
Unplug the power connections on the power supply board by pressing down the tabs on the connections and gently pulling the connections away from the board.
Remove the five 10 mm silver, coarse threaded Phillips #0 screws securing the power supply board to the case.
Unlatch white clips from the power supply board by pushing in the tabs and lifting up on the motherboard.
Remove the power supply board from its protective case by pulling it straight up and away from the case.
Еще один человек закончил это руководство.
