Введение
How to remove the cutting head for replacement or further device service in a Mk Diamond Wet Saw MK660 2010.
Loosen the plastic knob holding the saw's cutting head in place.
Lower the cutting head while keeping it steady.
Loosen the wing nut on the blade cover pivot shaft.
Remove the wing nut and accompanying washer.
Insert the provided spanner wrench into one of the four tightening holes on the inner flange behind the blade.
Use the the provided nut wrench to loosen the hex nut while providing counterforce with the spanner wrench.
Pull the entire cutting head straight off the shaft holding it in place.
