Выберете то, что вам нужно
Remove the speaker wires from the motherboard by pinching the plastic tab at the end of the cable and pulling towards you.
Unscrew 1.2 cm Torx security screw, holding the silver circle connector, to disconnect the wire from the speakerboard to the motherboard
Remove the black putty from the speaker wires at both ends of the speaker board.
Tuck wires through the hole where the speaker is located, then gently push the speaker out.
Еще один человек закончил это руководство.
