Введение
Use this guide to replace the front speaker grille
Выберете то, что вам нужно
Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
Remove the five 10mm screws with a TR 10 screwdriver.
Use a spudger to break the remaining adhesive holding the grille to the speaker body.
Flip speaker around and use a plastic opening tool to remove the top panel from the speaker.
Use a plastic opening tool to remove the foam and uncover four more screws.
Use a TR 10 screwdriver to remove the five 10mm screws on the top of the speaker.
Use a TR 10 screwdriver to remove two of the 10mm screws that secure the speaker grille.
With the top panel removed, use a spudger to remove the display panel.
Use a TR 10 screwdriver to remove the four final 10mm screws securing the speaker grille.
3 участников успешно повторили данное руководство.
