Введение
This is a guide for replacing the cassette player on the left side of the unit.
Выберете то, что вам нужно
Remove the nine 35 mm Phillips screws securing the back cover of the case.
Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
Remove the following 6 screws:
Four 25 mm Phillips
Two 2.5 mm Flathead
Move the brass plate with attached pneumatic cylinder on the left-hand side.
Detach the plate at the pneumatic cylinder and leave the plate attached to the torsional spring.
Stand the unit up and press eject to open the door on the cassette player.
Gripping the cassette player from the back, lift upwards on the door to unclip it from the bar around which it rotates. This may take some effort.
