Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If the buttons on the front of the device aren't responding, you may have a faulty button board. Follow the instructions below to replace your button board.
Выберете то, что вам нужно
Slide the battery lock switch next to the power slider to the unlocked position.
Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
Unscrew hard drive panel using a Phillips head #1 screwdriver.
(Our device was not given to us with a hard drive or a hard drive panel)
To disconnect the three white ribbon cables on the side closest to the hard drive connector, pull the white plastic tabs.
To disconnect the remaining ribbon cables, pull the plastic connectors away from their connections.
With a Phillips #1 screwdriver, Unscrew the nine 10mm screws holding the case together.
Using a spudger, press in the five tabs on the side where the battery was.
This should separate the two halves of the device. Carefully set the side with the motherboard off to the side.
Unplug the three ribbon cables by pulling on the brown tabs and unplugging cable.
With a Phillips #1 screwdriver, unscrew the three 4mm screws holding the display bracket on the back side of the front buttons.
