Введение
Use this guide to remove the earpiece speaker in the Motorola Moto C Plus.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Выберете то, что вам нужно
Insert a thumbnail, or spudger, into the notch on the bottom right to start separating the phone unit from the back cover.
Move to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
Use a spudger or fingernail to lift the battery starting at the notch on the bottom left.
Lever the battery out of its recess and remove it.
Remove the six 3.1 mm Phillips #00 screws securing the daughterboard cover.
Apply a spudger to the right side of the daughterboard cover.
Twist the spudger sideways to pry up the daughterboard cover until you get a good grip.
Remove the daughterboard cover.
Apply an opening pick to the bottom right corner of the motherboard cover.
Twist the opening pick to free the motherboard cover out of the plastic clamps on the right side of the phone.
Repeat the previous step on the left side of the motherboard cover to free it out of the plastic clamps.
Pry up the motherboard cover until you can get a good grip.
Remove the motherboard cover.
Remove the two 3.2 mm Phillips #00 screws securing the motherboard.
Use the tip of a spudger to lift the latch on the power and volume button ZIF connector.
Use a pair of tweezers to pull the power and volume button flex cable out of the ZIF connector.
Fold the power and volume button flex cable out of the way.
Pry up and disconnect the antenna cable.
Fold the antenna cable out of the way.
Use the tip of a spudger to open the interconnect cable ZIF connector by lifting the brown flap.
Use a pair of tweezers to pull the interconnect flex cable out of the ZIF connector.
Use the tip of a spudger to open the flap of the ZIF connector next to the headphone jack.
Use a spudger to carefully lift the motherboard until you can get a good grip. Avoid to damage the cables next to the motherboard.
Lift the motherboard and fold it back until you have enough space to disconnect the display flex cable.
Use the edge of a spudger to pry up and disconnect the display flex cable from the motherboard.
Use an iOpener and apply it to the top edge of the display to loosen the adhesive beneath the earpiece speaker.
2 участников успешно повторили данное руководство.
