Введение
Prerequisite-only guide for removing the midframe from the Moto G4, in order to access internal components for servicing.
Запчасти
No parts specified.
  1. Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port. Gently twist or pry to open a small gap between the back cover and the body of the phone. While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
    • Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
    • Gently twist or pry to open a small gap between the back cover and the body of the phone.
    • While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
  2. Slide your tool all along the side of the phone to separate more of the clips securing the back cover. Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
    • Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
  3. Keep your tool inserted slightly under the back cover, and slide it around the top corner. If necessary, continue prying around the remaining edges of the phone until the back cover comes free. If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
    • Keep your tool inserted slightly under the back cover, and slide it around the top corner.
    • If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
  4. Remove the back cover. To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
    • Remove the back cover.
    • To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
  5. Комплект инструментов для замены батареи Macbook
    Доступно с $69.99
    Buy Now
    Доступно с $69.99
    Buy Now
  6. Slide out and remove the MicroSD and SIM card trays (if installed). Slide out and remove the MicroSD and SIM card trays (if installed).
    • Slide out and remove the MicroSD and SIM card trays (if installed).
  7. Use a spudger to pry up the rubber cover for the camera flash connector. Use a spudger to pry up the rubber cover for the camera flash connector.
    • Use a spudger to pry up the rubber cover for the camera flash connector.
  8. Remove the rubber cover.
    • Remove the rubber cover.
  9. Use a spudger to disconnect the camera flash connector by prying it straight up. Use a spudger to disconnect the camera flash connector by prying it straight up.
    • Use a spudger to disconnect the camera flash connector by prying it straight up.
  10. Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
    • Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
  11. Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
    • Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
  12. Remove the midframe.
    • Remove the midframe.
Заключение
Jeff Suovanen
Участник с: 06.08.2013
222 350 Репутация
Автор 190 руководств
Команда
iFixit Member of iFixit
Community
104 членов
Автор 8 384 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 25
