Введение
Перейти к шагу 1 ↓Use this guide to replace the screen on your Moto G6 Play, including the midframe which is glued to the display.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Make sure your replacement part includes both the display and the midframe—this guide does not cover separating the display from the midframe.
If your battery is swollen, take appropriate precautions.
This procedure involves removing the battery, which may be damaged during the removal process. We strongly advise you do not reuse the battery as doing so may pose a safety hazard. Replace it with a new battery.
Выберете то, что Вам нужно
Ремонтный комплект
Этот комплект содержит все детали и инструменты, используемые в инструкции.
Запчасти
Инструменты
Spudger4.9
Insert a paperclip or SIM card eject tool into the small hole in the SIM card tray on the upper right edge of the phone.
Press the tool into the hole to eject the tray.
If possible, drain the battery before disassembly. When the battery is charged, there's an increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
Apply a suction cup to the bottom edge of the rear glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Insert an opening pick into the gap you created under the rear glass.
Slide the pick all along the bottom edge of the phone to slice through the adhesive securing the rear glass.
Slide the pick along the right edge of the rear glass to separate the adhesive underneath.
Leave the pick under the top right corner of the glass to prevent the adhesive from re-adhering. Continue with a new pick.
Slide the pick all along the top edge of the phone to slice through the adhesive securing the rear glass.
Leave the pick under the top left corner of the glass to prevent the adhesive from re-adhering. Continue with a new pick.
Slide a pick along the left edge of the phone to slice through the rear glass adhesive.
There are two strips of adhesive on either side of the lower half of the phone that must be separated to remove the rear glass panel.
You will need to release these adhesive strips without damaging the fingerprint sensor cable located in the center of the phone.
Insert the flat end of a spudger into the lower half of the right side of the phone about 2 cm and slide it down the right edge to release the right strip of adhesive.
Insert a spudger into the lower half of the left side of the phone about 2 cm and slide it down the left edge to release the left strip of adhesive.
Инструмент, используемый на этом этапе:Tesa 61395 Tape$8.95
If the glass remains stuck, re-heat and slice any remaining adhesive repeatedly as needed.
Lift the rear glass carefully, making sure it's fully separated from any adhesive.
Open the rear glass.
Use a Phillips screwdriver to remove the two screws securing the fingerprint sensor cable retention bracket:
One silver 1.5 mm screw
One gold 3.5 mm screw
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a pair of tweezers to remove the fingerprint sensor cable retention bracket.
Use a Phillips screwdriver to remove the fifteen gold 3.5 mm screws securing the plastic midframe.
Insert a spudger into the notch on the upper right edge of the midframe.
Pry the midframe up to release the clips securing it to the device's aluminum frame.
Remove the plastic midframe.
Use a spudger to pry up and disconnect the battery cable.
Prepare an iOpener and apply it to the middle of the screen, directly behind the battery, for at least two minutes, in order to soften the battery adhesive underneath. Reheat and reapply the iOpener as needed.
Carefully insert an opening pick under the bottom of the battery.
Gradually push the pick further under the battery to pry up the bottom edge.
Slide the pick all along the bottom edge to release the bottom of the battery.
Move the pick to the bottom left corner of the battery and begin prying the left edge.
Slide the pick all along the left edge to release the adhesive strip under the left side of the battery.
Move the pick to the bottom right corner of the battery and begin prying the right edge.
Slide the pick all along the right edge to release the adhesive strip under the right side of the battery.
Use the pick to steadily pry the battery up.
Remove the battery.
Remove the two adhesive strips on either side of the battery well.
Use a pair of tweezers to carefully remove the tape covering the camera module connector.
Use the flat end of a spudger to pry up the camera module connector and disconnect it.
Remove the camera module.
Insert the pointed end of a spudger underneath the bottom left corner of the earpiece speaker and pry it up.
Remove the earpiece speaker.
Use a spudger to pry up and disconnect the daughterboard flex cable.
Use the pointed end of a spudger to pry up and disconnect the black antenna cable.
Use the pointed end of a spudger to pry up and disconnect the blue antenna cable.
Use a Phillips screwdriver to remove the single silver 2 mm screw securing the daughterboard.
Use the pointed end of a spudger to pry up the top left corner of the daughterboard.
Remove the daughterboard.
Use a spudger to pry up and disconnect the daughterboard flex cable from the motherboard.
Use a pair of tweezers to remove the piece of tape covering the side button flex cable connector.
Retain this piece of tape for reassembly.
Use the pointed end of a spudger to flip up the locking flap on the side button ZIF connector.
Use a Phillips screwdriver to remove the two silver 2 mm screws securing the motherboard.
Use the pointed edge of a spudger to pry up the top right corner of the motherboard.
Remove the motherboard.
Use a pair of tweezers to remove the black strip of tape covering the antenna cables.
Remove the two antenna cables from their channel in the side of the battery well.
Peel up the daughterboard flex cable and remove it.
Use a pair of tweezers to remove the daughterboard cable adhesive.
Try to keep this piece of tape as intact as possible for reassembly.
Use a pair of tweezers to remove the small silver side button retention bracket from the left side of the device.
Use the point of a spudger to push against the back of the volume button, behind its lower end, so that the lower end of the button slides out of the phone first.
Use tweezers to gently remove the volume button, by pulling it from its lower end.
Use the point of a spudger to push against the back of the power button, behind its upper end, so that the upper end of the button slides out of the phone first.
Use tweezers to gently remove the power button, by pulling it from its upper end.
Insert an opening pick between the power and volume button circuit board and the frame.
Slide the pick behind the circuit board, across the whole board, to separate it from the adhesive securing it to the frame.
Use tweezers to carefully pull the volume and power button circuit board out of its slot. If it's difficult to remove, make sure you've sliced through all its adhesive.
Only the screen assembly remains.
Compare your new replacement part to the original part—you may need to transfer additional components or remove adhesive backings from the new part before installing.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Moto G6 Play Answers Community for help.
7 человек успешно провели ремонт по этому руководству.
