Введение
This process involves removing the battery, outer case, and motherboard. After, the microphone can be removed.
Выберете то, что вам нужно
Hold the phone and pull the back latch down towards the bottom.
Remove the back panel by releasing the latch and lifting from the top.
Once the battery is out, unscrew the six 7.0 mm screws with T-6 screwdriver.
Once the screws are removed, simply lift the back panel off
Почти готово!
Заключение
