Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Using a screwdriver, remove the four screws that are visible.
After removing the battery chamber, unclip one of the ribbons that connect the screen to the main body of the phone. This divides the phone in half.
Remove the two screws located at the bottom of the main display.
Remove the display screen by sliding a sharp object or fingernail along the edge of the housing.
Release the display up to the point where you see two metal parts (left and right of the Motorola text). The top part of the display is held on with double-sided tape.
Gently unstick the tape and remove the display. Be careful not to bend this part.
2 участников успешно повторили данное руководство.
