Введение
To remove the LCD you will first need to remove the battery, open the phone and remove the motherboard. Be ready to use a plastic opening tool, T5 Torx Screwdriver, spudger and head gun or hair dryer.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Spudger$3.99
Insert a spudger into the small notch at the base of the battery.
Lift the battery out of the phone.
Инструмент, используемый на этом этапе:T5 Torx Screwdriver$5.49
Remove the four 5.0 mm T5 Torx screws using a T5 Torx Screwdriver.
Remove the three 5.5 mm T5 Torx screws using a T5 Torx Screwdriver.
Инструмент, используемый на этом этапе:iFixit Opening Tool$1.99
Lift up the black rubber flap using an opening tool.
Remove the single 5.5 mm T5 Torx screw using a T5 Torx Screwdriver.
Gently lift the tabs located at the top of the phone using an opening tool.
Gently lift the tab located at the bottom of the phone with the same tool.
Insert an opening tool between the front and back of the case.
Slide the tool down the side of the phone.
Repeat the same process for the other side.
Slide an opening tool beneath the antenna and lift straight up from the motherboard.
Ease the antenna from out of its guide along the side of the phone
Remove the back case and the antenna from the phone.
Insert a spudger between the black plastic and the motherboard.
Lift upwards with the spudger to dislodge the board.
Disconnect the press connectors using a spudger.
Lift the white latch on the ZIF connector using a spudger.
Gently pull the black ribbon down and away from the latch.
There should be five distinct parts of the phone: the back cover, the back case, the front case, the battery, and the motherboard.
Using a heat gun or a hair dryer on high heat, soften the adhesive securing the glass screen.
Using a plastic opening tool, carefully pry up the bottom of the display glass.
Slowly work your way around the phone, using the plastic opening tool to separate the glass from the phone.
Now that the cable has been removed you can slide it through the opening and detach the glass.
Be careful as you pull the cable through the opening. The cable is easily damaged.
Once the cable is pushed through the slot, the glass can be fully removed.
With the glass removed you can now access the LCD screen.
Using a plastic opening tool, slide it in between LCD screen and the case of the phone and then pry it out carefully.
Slide the case opener tool along the side until the LCD pops out of the case.
Carefully guide the cables attached to the back of the LCD through the hole.
4 человек успешно провели ремонт по этому руководству.
