Запчасти
Никакие детали не требуются.
  1. Turn the phone so its back is facing you. Press the release button on the back cover, while simultaneously pulling the cover down.
    • Turn the phone so its back is facing you.
    • Press the release button on the back cover, while simultaneously pulling the cover down.
    • Remove the back cover.
  2. Pinch the sides of the bottom of the battery and pull upward. Pinch the sides of the bottom of the battery and pull upward.
    • Pinch the sides of the bottom of the battery and pull upward.
  3. Press and slide the SIM card down. Remove the SIM card.
    • Press and slide the SIM card down.
    • Remove the SIM card.
  4. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  5. Orient the phone so its back is facing you. Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
    • Orient the phone so its back is facing you.
    • Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
    • Note: If you are using iFixit's screwdriver toolkit, look for the smallest T-screwbit.
    • Lodge a spudger in between the front panel and the main frame of the phone.
    • Using a good amount of torque, pry the front panel from the phone.
    • Turn the phone to its natural orientation.
    • Insert a spudger at the bottom of the phone, between the phone's frame and the circuit board.
    • Pry the circuit board from the frame.
    • Note: Prying away the board takes more force than you would expect.
  6. Bend the screen clamps outward so they are no longer underneath the circuit board. Pull the screen encasing away from the circuit board.
    • Bend the screen clamps outward so they are no longer underneath the circuit board.
    • Pull the screen encasing away from the circuit board.
    • Caution: The screen-to-phone interface will still be connected.
  7. Unplug the screen-to-phone interface. Remove the screen from its encasing by pushing it out.
    • Unplug the screen-to-phone interface.
    • Remove the screen from its encasing by pushing it out.
Заключение
Christopher Wu
Участник с: 17.04.2012
19 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 12-40, Regan Spring 2012 Member of Cal Poly, Team 12-40, Regan Spring 2012
CPSU-REGAN-S12S12G40
4 членов
Автор 8 руководств
Комментариев: 2
motorola c168 network not working problem. how to repair network problem?
sattar - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 2
За всё время: 1,140
