Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
Turn the phone so its back is facing you.
Press the release button on the back cover, while simultaneously pulling the cover down.
Remove the back cover.
Orient the phone so its back is facing you.
Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
Bend the screen clamps outward so they are no longer underneath the circuit board.
Pull the screen encasing away from the circuit board.
Unplug the screen-to-phone interface.
Remove the screen from its encasing by pushing it out.
Еще один человек закончил это руководство.
